Hello, 1 have 3 different SE servers. One router need to link l2tp to each server. But all the servers have 1.0.0.1 local ip. Routing problems.. :/
how to change this?
thanks for help!
change 1.0.0.1 ?
shakibamoshiri
Re: change 1.0.0.1 ?
I have seen 1.0.0.1 on mikrotik when from mikrotik a SSTP client is connected to a SE server
how have you setup your network?
I think you no need to change 1.0.0.1, you should be able to router to it
kaurich
I need 1 mikrotik to be connected to 3 different SE SERVERS.. route to 1.0.0.1 appears automatically..
ip route looks like "1.0.0.1 via l2tp1, l2tp2, l2tp3" automatically... links unstable.
that is why i need to change 1.0.0.1 on SE server. OS Linux.
wrgoababd
did you manage to solve the problem with the unreal vpn server address?
I need to set a real IP address of the VPN server in order to configure routing on mikrotik.
for example 192.168.30.1
adroman
I have the same problem with wrong IP address?
Were you able to solve it?
kamalRadwan
I also Have the same problem and i couldn't solve it
