Such high disk IO usage when VPN is activated!
I want to use this VPN, but when it is connected it is constantly writing up to 20 MB/second to my disk. No other VPN does this, is this a bug? It does this even when there is no network activity at all, but either way, shouldn't it be recieving into memory?
Re: Such high disk IO usage when VPN is activated!
SE has
- security log
- packet log
- server log
You can disable security and packet log and check if disk IO will be gone or not,
If not, you may report it on github
- security log
- packet log
- server log
