docs - server manual - configuration file - wrong wording
bannam.crotag
Post by bannam.crotag » Mon Jul 17, 2023 8:44 am
here:
https://www.softether.org/4-docs/1-manu ... ation_File
it says:
"It is necessary to avoid the use of file system's which do not feature the FAT or FAT32 permission concepts"
I think it should be like so:
"It is necessary to avoid the use of file systems like FAT or FAT32 which do not feature these permission concepts"
Best regards
bannam.crotag
doc - server manual - adminip.txt - mix-up
Post by bannam.crotag » Mon Jul 17, 2023 9:14 am
Hello again,
here:
https://www.softether.org/4-docs/1-manu ... .txt_Files
it says:
"When end of a line starts with # or //, the line is treated as a comment and is ignored."
I think it should be:
"If a line starts with # or //, the line is treated as a comment and is ignored."
Bye
