how to use/set Obfuscation and ObfuscationMask
shakibamoshiri
Post by shakibamoshiri » Sun Aug 20, 2023 1:20 pm
Anyone has used these two options for OpenVPN (5.X dev version) ?
- Obfuscation
- ObfuscationMask
vpncmd help
Obfuscation                 |Boolean                |False              |This may help an OpenVPN client bypass firewalls that are aware of the protocol and block it. The same XOR mask has to be applied client-side, otherwise it will not be able to connect with certain obfuscation methods!
ObfuscationMask             |String                 |                                 |Mask used to XOR the bytes in the packet (used for certain obfuscation modes).
Server and client file should be configured correctly.
If you used please guide
Regards
shakibamoshiri
Re: how to use/set Obfuscation and ObfuscationMask
Post by shakibamoshiri » Sun Aug 20, 2023 3:04 pm
found this guidance for standalone OpenVPN
https://lowendtalk.com/discussion/21539 ... ambled-vpn
and applying this option
scramble obfuscate guardian
I tested and did not work
