Dears, I got some problem need your help.
Home Router (DHCP) 192.168.2.1
host machine CentOS 6.8
eth0 & vnet0 in br0
br0 ip 192.168.2.100
vnet0 192.168.2.101(windows7 guest os)
If I set local bridge to eth0 vpn client can only connect to 192.168.2.1
If I set local bridge to br0 vpn client can connect o 192.168.2.1 & 101
I want to connect to 192.168.2.100, What should I do?
problem on linux with local bridge
kaa
Re: problem on linux with local bridge
http://www.vpnusers.com/viewtopic.php?f ... ode#p16687
I fix it following Mada 's reply. Thanks all :D
