most people in the current era are using Andyoid system phones. Why not write an Andyoid version of the SoftEther Vpn cl
tenghueijie
なぜAndyoid版のSoftEther Vpn clientのアプリを編集しないのか
Post by tenghueijie » Wed Nov 01, 2023 6:48 am
プログラミングエンジニアの皆さん、こんにちは。今の時代の人の多くはAndyoidシステム携帯電話を使っていますが、なぜAndyoid版のSoftEther Vpn clientのアプリを編集しないのか、そのまま使うことができます。ユーザーごとのコンピュータの長期的な電源投入による電力消費やネットワーク接続のためのネットワークリソースの占有を省き、プログラミングエンジニアが早くAndyoidシステムのSoftEther Vpn clientのappを作成することを期待しています。
tenghueijie
Post by tenghueijie » Wed Nov 01, 2023 7:17 am
Hello program engineers, most people in the current era are using Andyoid system phones. Why not write an Andyoid version of the SoftEther Vpn client app so that it can be used directly. Eliminating the long-term power consumption and network resource consumption of each user's computer, I hope that program engineers can write the SoftEther Vpn client app for the Andyoid system as soon as possible.
shakibamoshiri
Re: most people in the current era are using Andyoid system phones. Why not write an Andyoid version of the SoftEther Vp
Post by shakibamoshiri » Sat Nov 04, 2023 5:39 pm
Thanks for the feedback
The main focus of this software is not an Android app,
If you have an Android device (below v12) you can use L2TP, for upper Android version IKEv2 has not been implemented yet. And you can use OpenVPN or SSTP on Android to connect as well.
