Address and Host name issue
stariyal91
Post by stariyal91 » Tue Nov 07, 2023 2:20 pm
Hi, I have set up the SoftEther VPN Client and am trying to connect to the Client VPN. The client provided me with a "VPN Client Connection Setting File," but when I try to connect using this file, I encounter an error related to the address and host name. Please provide a solution.
shakibamoshiri
Re: Address and Host name issue
Post by shakibamoshiri » Thu Nov 09, 2023 9:34 pm
where did you or how did you get the file.vpn from?
The file.vpn is exported from an SE Windows client. If you got from somewhere/someone else,
1. open SE client > Menu > connect > Import VPN connection settings ...
2. Right client on loaded file name > properties
3. check the missing parts
