only the api
heydariomid4
only the api
Post by heydariomid4 » Sat Mar 09, 2024 3:43 pm
Hello, how can I activate only the api, then it says that the options are not active, like web server management?
shakibamoshiri
Re: only the api
Post by shakibamoshiri » Sat Mar 09, 2024 7:02 pm
API is active by default
check it out here
https://github.com/SoftEtherVPN/SoftEth ... pc-clients
heydariomid4
Re: only the api
Post by heydariomid4 » Tue Mar 12, 2024 6:46 pm
check it out here
Thankful🌹
