Update Softether Linux
CSM
How do I update Softether on Linux to latest version without losing any of my settings?
moatazelmasry
Re: Update Softether Linux
first You need to backup you settings.
All settings exist in
as far as I know all settings are vpn_server.config and certs/
After that it is a matter of downloading and extracting the newest SE version, extract it to the desired location then overwrite with the old settings from the previous step and then start SE
CSM
Thanks. Will give that a try.
