1st i would like to thank all who will help me out with this
am trying to create a LAN to LAN bridge connection using softether following the steps in this page
http://www.softether.org/4-docs/2-howto ... Bridge_VPN
i successfully installed and configured softether server on SiteA, and Bridge on SiteB with a successful connection between both, but am unable to ping or see any network shared folders.
Both are installed on Windows 7 pro
is there anything missing that i need to do other than configure and connect in order to work?
Lan to Lan Bridge
Re: Lan to Lan Bridge
Do network addresses of both site are same?
technocom
Hello thisjun
thanks for your reply, eventually after i kept on reading a lot and trying to understand how things work with softether i figured that either both sides need to have same IP Range, or i simply change the Subnet to one that bound both IP Ranges.
Now am trying to go more advanced with no luck as these tutorials are really hard to understand sometimes. is there a way where i can find more explained tutorials which simplify the configuration needed?
thanks in advance
thanks in advance
We only have this tutorial.
