Hello Team,
I disable network adapter (from Control Panel\Network and Internet\Network Connections) and softether client stop reties to reconnect.
I have set reconnects Automatically for infinite time but stop
webportable
Re: stop reties to reconnect
We have any idea for don't stop it ..?
moatazelmasry
Sorry the question is not clear. You disabled the network adapter, you set SoftEther to connect automatically. But you expect SoftEther to stop retrying to connect?
Why not just close SE program?
If there are some fatal error in the client, SoftEther VPN client stops to try to connect.
