Installation of the Virtual Network Adapter device driver failed
scottjameson
Post by scottjameson » Wed Jan 08, 2025 8:26 pm
Windows 11 Pro getting "Installation of the Virtual Network Adapter device driver failed" Windows user is local administrator, tried SoftEther beta version and latest non-beta version, same error. Ran installer "As Administrator" same error. cleared temp files, ran sfc /scannow, no errors. Connected to Internet via WiFi network marked as "Private". Have installed and setup SoftEther VPN on Windows many times on many computers over the last few years, first time to get this error, can't think of solution.
spp
Re: Installation of the Virtual Network Adapter device driver failed
Post by spp » Fri Jan 10, 2025 7:40 am
softether-vpnclient 5.02 5187 the same error occurs on latest Windows 10 with all updates.
Windows 7 displays a warning message about this driver, but the driver installs and works.
I suspect, this issue is related to an unsigned or incorrectly signed driver. Latest windows does not allow unsigned drivers.
Post by solo » Sun Jan 12, 2025 1:40 am
SE v4, Windows 11 - no problem whatsoever.
The OP got a Qualcomm Snapdragon Windows 11 - SE will not work on ARM64 (atm).
"Note that emulation only supports user mode code and does not support drivers; any kernel mode components must be compiled as Arm64."
https://learn.microsoft.com/en-us/windo ... -emulation
evg
Post by evg » Wed Jan 15, 2025 9:11 am
I've the same problem on Windows 11 PRO
AMD Ryzen 5 5560U with Radeon Graphics 2.30 GHz
I also can't edit the Windows created VPN virtual network adapter, but Kerio and Zyxel Vpn clients work fine.
Post by solo » Wed Jan 15, 2025 9:27 am
v5 is a DEVELOPER EDITION, bugs are expected.
Incidentally, softether-vpnclient-5.02.5378.x64 works fine https://dev.azure.com/SoftEther-VPN/Sof ... _a=summary
iheis
Post by iheis » Sun May 04, 2025 12:08 pm
Where can I download the version softether-vpnclient-5.02.5378.x64 or newer.
Or could someone provide it for me.
I have a Snapdragon CPU.
Post by solo » Sun May 04, 2025 1:26 pm
Read above viewtopic.php?f=7&p=103475#p102938
There is no such version for Snapdragon aka ARM64.
