[OK] SoftEther VPN off = download software off to
ToBLeRoNe
I use this soft for a few months now and I am satisfied.
However, sometimes I get disconnected. So, I would like to automatically, that softwares running are also turned off when I lose my connection with SoftEther.
Thank you and forgiven my English.
moatazelmasry
Re: SoftEther VPN off = download software off to
Which software should be turned off when you lose your connection?
ToBLeRoNe
For example utorrent.
ToBLeRoNe
There is a solution for utorrent ?
Thanks.
Thanks.
Mada
> Thanks.
You should use the firewall to solve this.
> Thanks.
ToBLeRoNe
> > Thanks.
I try to use firewall, but i miss.
My OS is Windows XP
> > Thanks.
My OS is Windows XP
ToBLeRoNe
> > > Thanks.
> My OS is Windows XP
There is another way to solve this ?
Can we use OpenVPN with the same list VPN into SoftEther?
> > > Thanks.
> My OS is Windows XP
moatazelmasry
Are you using the SoftEther client to connect?
In this case, please try OpenVPN client. Maybe this will solve your problem
Regards
Regards
ToBLeRoNe
> Regards
Thanks ! Done :D
> Regards
Thanks ! Done :D
