[Windows] VPNClient becomes isolated from LAN
Elezorn
Post by Elezorn » Mon Nov 10, 2025 11:10 pm
Hello everyone
There's a machine with some service running on it(ex. file/web server) which is accessible across whole LAN via address:port. But when User starts a vpnclient session then physical connection(ethernet or wifi) becomes marked as "Unidentified" and can't be changed and services are no longer accessible by anyone.
Tried playing with interface metrics, but the only two states are:
either whole traffic goes through vpn tunnel(which is good) and local service not accessible LAN-wise
or
vpn tunnel active with traffic not going through it(which is bad) and local service accessible LAN-wise
So the main idea/question is: Is it possible for windows machine to have local shares/services not being isolated from LAN while whole traffic goes through tunnel? Same config works on official Linux client and 3rd party android client. Am I missing something or is there some limitations?
Thanks
Re: [Windows] VPNClient becomes isolated from LAN
Post by solo » Tue Nov 11, 2025 8:24 am
Disable TunnelCrack protection.
Elezorn
Post by Elezorn » Sun Nov 16, 2025 10:16 am
Toggling TunnelCrack protection as well as "Windows network optimization"/recreating vpn adapter/running as user or admin doesn't change anything. Tried on two versions on VPN Client:
W10 19045.6456
VPN Adapter 4.25.9658
SE Client 4.43 Build 9799
SE Client 4.44 Build 9807
Post by solo » Sun Nov 16, 2025 1:16 pm
Please start a VPN on the client and post as code the output of:
netstat -r
ping LAN-gateway-IP
Elezorn
Post by Elezorn » Sun Nov 16, 2025 4:13 pm
netstat -r
ping LAN-gateway-IP
Ping to local gateway
C:\Users\ELEZO>ping 192.168.1.1
Обмен пакетами с 192.168.1.1 по с 32 байтами данных:
Ответ от 192.168.1.1: число байт=32 время=3мс TTL=64
Ответ от 192.168.1.1: число байт=32 время=2мс TTL=64
Статистика Ping для 192.168.1.1:
    Пакетов: отправлено = 4, получено = 4, потеряно = 0
    (0% потерь)
Приблизительное время приема-передачи в мс:
    Минимальное = 2мсек, Максимальное = 3 мсек, Среднее = 2 мсек
Ping to remote gateway (thru VPN tunnel)
C:\Users\ELEZO>ping 192.168.100.1
Обмен пакетами с 192.168.100.1 по с 32 байтами данных:
Ответ от 192.168.100.1: число байт=32 время=59мс TTL=64
Ответ от 192.168.100.1: число байт=32 время=56мс TTL=64
Статистика Ping для 192.168.100.1:
    (0% потерь)
    Минимальное = 56мсек, Максимальное = 59 мсек, Среднее = 56 мсек
netstat
C:\Users\ELEZO>netstat -r
Список интерфейсов
  9...00 ff 0e c2 f5 5d ......TAP-Windows Adapter V9 for OpenVPN Connect
 64...b8 88 e3 74 a1 b6 ......Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
 73...........................OpenVPN Data Channel Offload
 26...ae e0 10 dd 27 c9 ......Microsoft Wi-Fi Direct Virtual Adapter #5
 17...ae e0 10 dd 2f c9 ......Microsoft Wi-Fi Direct Virtual Adapter #6
 10...00 50 56 c0 00 01 ......VMware Virtual Ethernet Adapter for VMnet1
 29...00 50 56 c0 00 08 ......VMware Virtual Ethernet Adapter for VMnet8
 48...5e 07 fa c5 19 63 ......VPN Client Adapter - VPN
 18...ac e0 10 dd 27 c9 ......Dell Wireless 1820A 802.11ac #2
 49...ac e0 10 dd 27 ca ......Bluetooth Device (Personal Area Network) #4
 24...b0 83 85 57 55 5a ......Sierra Wireless Mobile Broadband Network Adapter
IPv4 таблица маршрута
Активные маршруты:
Сетевой адрес           Маска сети      Адрес шлюза       Интерфейс  Метрика
          0.0.0.0          0.0.0.0    192.168.100.1   192.168.100.16     35
          1.1.1.1  255.255.255.255      192.168.1.1     192.168.1.69     35
     WAN.IP.THRU.VPN  255.255.255.255      192.168.1.1     192.168.1.69     35
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
     130.158.6.69  255.255.255.255      192.168.1.1     192.168.1.69     35
    130.158.6.126  255.255.255.255      192.168.1.1     192.168.1.69     35
      192.168.1.0    255.255.255.0         On-link      192.168.1.69    291
     192.168.1.69  255.255.255.255         On-link      192.168.1.69    291
    192.168.1.255  255.255.255.255         On-link      192.168.1.69    291
     192.168.19.0    255.255.255.0         On-link      192.168.19.1    291
     192.168.19.1  255.255.255.255         On-link      192.168.19.1    291
   192.168.19.255  255.255.255.255         On-link      192.168.19.1    291
    192.168.100.0    255.255.255.0         On-link    192.168.100.16    291
   192.168.100.16  255.255.255.255         On-link    192.168.100.16    291
  192.168.100.255  255.255.255.255         On-link    192.168.100.16    291
    192.168.145.0    255.255.255.0         On-link     192.168.145.1    291
    192.168.145.1  255.255.255.255         On-link     192.168.145.1    291
  192.168.145.255  255.255.255.255         On-link     192.168.145.1    291
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link    192.168.100.16    291
        224.0.0.0        240.0.0.0         On-link     192.168.145.1    291
        224.0.0.0        240.0.0.0         On-link      192.168.19.1    291
        224.0.0.0        240.0.0.0         On-link      192.168.1.69    291
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link    192.168.100.16    291
  255.255.255.255  255.255.255.255         On-link     192.168.145.1    291
  255.255.255.255  255.255.255.255         On-link      192.168.19.1    291
  255.255.255.255  255.255.255.255         On-link      192.168.1.69    291
Постоянные маршруты:
  Сетевой адрес            Маска    Адрес шлюза      Метрика
          0.0.0.0          0.0.0.0     10.106.90.18       1
IPv6 таблица маршрута
Активные маршруты:
 Метрика   Сетевой адрес            Шлюз
  1    331 ::1/128                  On-link
 10    291 fe80::/64                On-link
 29    291 fe80::/64                On-link
 10    291 fe80::59aa:9ce5:34c2:b635/128
                                    On-link
 29    291 fe80::9d9a:a7cb:3919:fcc4/128
                                    On-link
  1    331 ff00::/8                 On-link
 10    291 ff00::/8                 On-link
 29    291 ff00::/8                 On-link
  Отсутствует
Elezorn
Post by Elezorn » Sun Nov 16, 2025 8:23 pm
netstat -r
ping LAN-gateway-IP
netstat
Список интерфейсов
Активные маршруты:
Активные маршруты:
                                    On-link
                                    On-link
  Отсутствует
Ping to both remote and local gateways
Ответ от 192.168.100.1: число байт=32 время=57мс TTL=64
    (0% потерь)
    Минимальное = 56мсек, Максимальное = 57 мсек, Среднее = 56 мсек
Ответ от 192.168.1.1: число байт=32 время=4мс TTL=64
    (0% потерь)
    Минимальное = 2мсек, Максимальное = 4 мсек, Среднее = 2 мсек
Post by solo » Mon Nov 17, 2025 1:47 am
Yes and it is not only possible but just works by default when TunnelCrack protection is off. We need more tests.
- on 192.168.1.69 PC with the web server (or such) disable the firewall (temporarily).
- on 192.168.1.x LAN client of the web server stop SSDP Discovery service.
- start the VPN on 192.168.1.69 and then from 192.168.1.x ping 192.168.1.69
will siggel
Post by will siggel » Mon Nov 17, 2025 3:57 pm
the vpn disconnects my internet connection anytime i switch it on , but once i disconnect the vpn , the internet is restored .
what can i do?
Elezorn
Post by Elezorn » Thu Nov 20, 2025 10:46 am
Thank you, it was firewall after all. LAN clients are not Windows-based, so SSDP service is not applicable.
Disabling W10 firewall did make everything work as expected.
After some fiddling with its settings, mainly deleting and then adding desired applications again, web services are being accessible LAN-wise both via Windows machine's ip and hostname, while VPN tunnel is enabled.
Metrics for interfaces are set to auto, real interface's network is still marked as Unidentified while tunnel is up. But since everything's working that's not a problem.
