Why my ip isnt changed? It says connected but my ip isnt changed...
Can someone who knows the answer to solve it?
Connected but no ip assignment
fenice
Re: Connected but no ip assignment
You haven't given much detail about your set-up. If this is a SoftEther VPN running on your own server then why would you see a different IP address, it's going out to the internet on the same IP on which it arrived. If you're using VPNgate then it should be a different IP address because you've connected to another VPN server.
Perhaps if you gave a better description of what you're connecting to, what error messages (if any) you see and how you're determining that your "...ip isn't changed" and how does that relate to the title of this post which says "Connected but no ip assignment"
XxShiveRxX
I'm using VPN Gate - Client and connected to another server.
But when i checked my ip in the web, the ip isnt changed from before.
I already got connected status but no ip assignment when connecting to the vpn server from other people.
Is IP address assigned on virtual adapter?
Is default gateway added on routing table?
XxShiveRxX
yes yes
yes yes
Could you show the routing table and traceroute result?
