Not sure what packages I need. Getting this:
make[1]: Entering directory '/home/hans/vpnserver'
Preparing SoftEther VPN Server...
ranlib lib/libcharset.a
ranlib lib/libcrypto.a
ranlib lib/libedit.a
ranlib lib/libiconv.a
ranlib lib/libintelaes.a
ranlib lib/libncurses.a
ranlib lib/libssl.a
ranlib lib/libz.a
ranlib code/vpnserver.a
gcc code/vpnserver.a -O2 -fsigned-char -pthread -m64 -lm -ldl -lrt -lpthread -L./ lib/libssl.a lib/libcrypto.a lib/libiconv.a lib/libcharset.a lib/libedit.a lib/libncurses.a lib/libz.a lib/libintelaes.a -o vpnserver
/usr/bin/ld: code/vpnserver.a(vpnserver.o): relocation R_X86_64_32 against symbol `StopProcess' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Unix.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Cedar.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Connection.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Hub.o): relocation R_X86_64_32 against symbol `VPN_9670DF295170' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Interop_OpenVPN.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(IPsec_IPC.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(IPsec_PPP.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Layer3.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Link.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Client.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Command.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Console.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Database.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(DDNS.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(Interop_SSTP.o): relocation R_X86_64_32S against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(IPsec.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(IPsec_IKE.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(IPsec_IkePacket.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(IPsec_L2TP.o): relocation R_X86_64_32 against symbol `CmpL2TPQueueForRecv' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(VLan.o): relocation R_X86_64_32 against symbol `VPN_195628D02C07' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: code/vpnserver.a(IPsec_EtherIP.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s3_meth.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s3_srvr.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s3_clnt.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s3_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s3_enc.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s3_pkt.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s3_both.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s3_cbc.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s23_meth.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s23_srvr.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s23_clnt.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(s23_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(t1_meth.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(t1_srvr.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(t1_clnt.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(t1_lib.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(t1_enc.o): relocation R_X86_64_32S against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(t1_ext.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(d1_srvr.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(d1_clnt.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(d1_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(d1_pkt.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(d1_both.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(d1_srtp.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(ssl_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(ssl_cert.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(ssl_asn1.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(ssl_algs.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(bio_ssl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(ssl_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(t1_reneg.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(tls_srp.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libssl.a(d1_meth.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cryptlib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(mem.o): relocation R_X86_64_32S against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(mem_dbg.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ex_data.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(o_names.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(obj_dat.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(obj_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(obj_xref.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(md4_one.o): relocation R_X86_64_32 against `.bss' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(md5_one.o): relocation R_X86_64_32 against `.bss' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(sha1_one.o): relocation R_X86_64_32 against `.bss' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(sha256.o): relocation R_X86_64_32 against `.bss' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(sha512.o): relocation R_X86_64_32 against `.bss' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(hmac.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(set_key.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ecb_enc.o): relocation R_X86_64_32 against `.bss' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cbc_enc.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(des_enc.o): relocation R_X86_64_32S against symbol `DES_SPtrans' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(aes_misc.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_lib.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_ctx.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_print.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_shift.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_mult.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_curve.o): relocation R_X86_64_32S against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_key.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_oct.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ecp_nistz256.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(rsa_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(rsa_sign.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(rsa_asn1.o): relocation R_X86_64_32 against symbol `RSA_PSS_PARAMS_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(rsa_crpt.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(dsa_asn1.o): relocation R_X86_64_32 against symbol `DSA_SIG_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(dsa_sign.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(dh_asn1.o): relocation R_X86_64_32 against symbol `DHxparams_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(dh_key.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(dh_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(dh_ameth.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(eng_init.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(eng_pkey.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(tb_rsa.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(tb_dh.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(buffer.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(buf_str.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bio_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bss_mem.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bss_file.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bss_sock.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bss_conn.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bf_buff.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(b_print.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(b_sock.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(stack.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(lhash.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(rand_unix.o): relocation R_X86_64_32S against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(err.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(digest.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(evp_enc.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_des.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_idea.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_des3.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_camellia.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_rc4.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_aes.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(names.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_seed.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_rc2.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(m_md5.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(m_sha1.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(m_dss1.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(m_ecdsa.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p_sign.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p_verify.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(evp_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_null.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(c_allc.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(c_alld.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(evp_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(evp_pbe.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p5_crpt.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p5_crpt2.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pmeth_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pmeth_fn.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pmeth_gn.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(m_sigver.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_aes_cbc_hmac_sha1.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_aes_cbc_hmac_sha256.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(e_rc4_hmac_md5.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(a_object.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(a_bitstr.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(a_int.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(a_type.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(a_dup.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(a_i2d_fp.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_algor.o): relocation R_X86_64_32 against symbol `X509_ALGOR_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_pubkey.o): relocation R_X86_64_32 against symbol `X509_PUBKEY_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_sig.o): relocation R_X86_64_32 against symbol `X509_SIG_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_attrib.o): relocation R_X86_64_32 against symbol `X509_ATTRIBUTE_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_bignum.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_long.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_name.o): relocation R_X86_64_32 against symbol `X509_NAME_INTERNAL_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_x509.o): relocation R_X86_64_32 against symbol `X509_CINF_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_x509a.o): relocation R_X86_64_32 against symbol `X509_CERT_AUX_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_crl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(d2i_pr.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(t_pkey.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(tasn_new.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(tasn_fre.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(tasn_enc.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(tasn_dec.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(tasn_utl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(tasn_typ.o): relocation R_X86_64_32 against symbol `ASN1_INTEGER_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ameth_lib.o): relocation R_X86_64_32S against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_exten.o): relocation R_X86_64_32 against symbol `X509_EXTENSION_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(asn1_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(asn1_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(evp_asn1.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p5_pbe.o): relocation R_X86_64_32 against symbol `PBEPARAM_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p5_pbev2.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p8_pkey.o): relocation R_X86_64_32 against symbol `PKCS8_PRIV_KEY_INFO_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pem_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pem_all.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pem_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pem_x509.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pem_xaux.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pem_oth.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pem_pkey.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_cmp.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_obj.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_vfy.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509name.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_v3.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_lu.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x_all.o): relocation R_X86_64_32 against symbol `X509_CINF_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_txt.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_trs.o): relocation R_X86_64_32S against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(by_file.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(by_dir.o): relocation R_X86_64_32S against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(x509_vpm.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_conf.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_lib.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_utl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_genn.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_alt.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_skey.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_akey.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_pku.o): relocation R_X86_64_32 against symbol `PKEY_USAGE_PERIOD_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_sxnet.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_cpols.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_crld.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_purp.o): relocation R_X86_64_32S against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_info.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_ocsp.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_akeya.o): relocation R_X86_64_32 against symbol `AUTHORITY_KEYID_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_pmaps.o): relocation R_X86_64_32 against symbol `POLICY_MAPPING_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_pcons.o): relocation R_X86_64_32 against symbol `POLICY_CONSTRAINTS_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_ncons.o): relocation R_X86_64_32 against symbol `NAME_CONSTRAINTS_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_pcia.o): relocation R_X86_64_32 against symbol `PROXY_POLICY_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_pci.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pcy_cache.o): relocation R_X86_64_32 against symbol `policy_data_free' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pcy_data.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pcy_map.o): relocation R_X86_64_32 against symbol `POLICY_MAPPING_free' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pcy_tree.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(v3_scts.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(conf_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(conf_api.o): relocation R_X86_64_32S against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(conf_def.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(conf_mod.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pk7_asn1.o): relocation R_X86_64_32 against symbol `PKCS7_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pk7_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pkcs7err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pk7_doit.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pk7_attr.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_asn.o): relocation R_X86_64_32 against symbol `PKCS12_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_crpt.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_crt.o): relocation R_X86_64_32 against symbol `PKCS12_SAFEBAG_free' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_init.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_key.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_kiss.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_mutl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_utl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pk12err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(p12_p8d.o): relocation R_X86_64_32 against symbol `PKCS8_PRIV_KEY_INFO_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(comp_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(comp_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(c_zlib.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ocsp_asn.o): relocation R_X86_64_32 against symbol `OCSP_SIGNATURE_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ocsp_ht.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ocsp_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ui_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cms_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cms_env.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cms_enc.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cms_pwri.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cms_kari.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(pqueue.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ts_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(srp_lib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(srp_vfy.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cm_pmeth.o): relocation R_X86_64_32S against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cpt_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(obj_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(hm_ameth.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(hm_pmeth.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cfb64ede.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(cfb_enc.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(aes_wrap.o): relocation R_X86_64_32 against symbol `AES_encrypt' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(rc2_skey.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(rc2_cbc.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(i_cbc.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(i_ecb.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(seed.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(seed_cbc.o): relocation R_X86_64_32 against symbol `SEED_encrypt' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(seed_cfb.o): relocation R_X86_64_32S against symbol `SEED_encrypt' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(seed_ofb.o): relocation R_X86_64_32S against symbol `SEED_encrypt' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(gcm128.o): relocation R_X86_64_32S against symbol `gcm_gmult_clmul' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(wrap128.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_add.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_div.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_exp.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_mul.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_mod.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_rand.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_blind.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_gcd.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_prime.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(rsaz_exp.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_recp.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(bn_mont.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ecp_smpl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ecp_mont.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_err.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_asn1.o): relocation R_X86_64_32 against symbol `EC_PRIVATEKEY_it' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec2_smpl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec2_mult.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_ameth.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libcrypto.a(ec_pmeth.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC01
/usr/bin/ld: lib/libedit.a(hist.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(key.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(map.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(parse.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(prompt.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(read.o): relocation R_X86_64_32S against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(refresh.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(search.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(sig.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(term.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(tty.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(vi.o): relocation R_X86_64_32 against symbol `cv__isWord' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(vis.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(tokenizer.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(history.o): relocation R_X86_64_32S against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(filecomplete.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(fcns.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(help.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(emacs.o): relocation R_X86_64_32 against symbol `ce__isword' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libedit.a(unvis.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_mouse.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_printw.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_scanw.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(tty_update.o): relocation R_X86_64_32 against symbol `_nc_outch' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_acs.o): relocation R_X86_64_32 against symbol `acs_map' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_options.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_setup.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_termcap.o): relocation R_X86_64_32S against symbol `_nc_globals' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_ti.o): relocation R_X86_64_32S against symbol `boolnames' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_tparm.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_tputs.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(read_entry.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(setbuf.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(trim_sgr0.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(unctrl.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_color.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_mvcur.o): relocation R_X86_64_32 against symbol `_nc_outch' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_tstp.o): relocation R_X86_64_32S against symbol `_nc_outch' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_vidattr.o): relocation R_X86_64_32 against symbol `_nc_outch' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(comp_error.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(db_iterator.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(home_terminfo.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(init_keytry.o): relocation R_X86_64_32S against symbol `_nc_tinfo_fkeys' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_baudrate.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_set_term.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(lib_slkrefr.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libncurses.a(resizeterm.o): relocation R_X86_64_32 against symbol `_nc_prescreen' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(compress.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(uncompr.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(deflate.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(trees.o): relocation R_X86_64_32S against `.data' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(zutil.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(inflate.o): relocation R_X86_64_32 against symbol `zcalloc' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(inftrees.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(inffast.o): relocation R_X86_64_32S against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(crc32.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libintelaes.a(intel_aes.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
Makefile:18: recipe for target 'i_read_and_agree_the_license_agreement' failed
make[1]: *** [i_read_and_agree_the_license_agreement] Error 1
make[1]: Leaving directory '/home/hans/vpnserver'
Build SE on xubuntu
Mada
Re: Build SE on xubuntu
This problem occurred with the source downloaded from softether.com. I used git clone instead and compilation went through without errors.
