I have done setup of soft-ether server on RHEL7.2.
When I am connecting soft-ether client from windows 8.1, it's getting connected and DHCP allocates virtual IP.
When I am connecting soft-ether client from other RHEL7 machine, DHCP is not able to get virtual IP.
It shows connected when executing accountinfo command,
Is there any configuration that i'm missing for DHCP server ?
Regards,
Mehul
Virtual IP address is not getting allocated from DHCP
Mehul2802
moatazelmasry
Re: Virtual IP address is not getting allocated from DHCP
Are you using SecureNAT or a bridge?
Which VPN protocol are you using to connect?
Mehul2802
After enabling secure NAT, DHCP assigns IP to softether client. e.g. 192.168.30.10
But, I am not able to ping softether client IP from softether server on windows.
Firewall is disabled and I have enabled Local bridging.
moatazelmasry
What is the IP of the client? is it in the same subnet as the server?
Mehul2802
No.
IP of Soft-ether Server: 192.168.6.169
IP address allocated to client by DHCP: 192.168.30.10 (When enabling Secure NAT and DHCP)
Assigning IP address is responsibility of client OS.
Please configure network setting for DHCP or run dhclient manually.
Mehul2802
@thisjun
After running
$ dhclient tap_soft
command on server, it gets new IP address in the range which is defined in virtual DHCP configuration of soft-ether.
Thanks,
Mehul
After running
$ dhclient tap_soft
Thanks,
Mehul
