I am using the vpnserver.service supplied from github. The paths are for debian som I changed them to suit xubuntu.
The vpnserver starts if I call it manually but when systemd tries to start it it fails. vpnserver complains about hamcore.se2
That file is in the same directory as vpnserver.
How do I make it find the file when starting as systemd?
Problem starting vpnserver with systemd on xubuntu
Mada
moatazelmasry
Re: Problem starting vpnserver with systemd on xubuntu
Are you using the same init script as on this page?
https://www.softether.org/4-docs/1-manu ... igurations
Also instead of:
./vpnserver start
try:
./vpnserver execsvc
Also instead of:
./vpnserver start
try:
./vpnserver execsvc
Mada
No, that is for systemV/upstart. I thought, since a systemd script is now provided, it would be better to use systemd for a newer Ubuntu distro. This is the scrip:
[Unit]
Description=SoftEther VPN Server
After=network.target auditd.service
ConditionPathExists=!/opt/vpnserver/do_not_run
[Service]
Type=forking
EnvironmentFile=-/opt/vpnserver
ExecStart=/opt/vpnserver/vpnserver start
ExecStop=/opt/vpnserver/vpnserver stop
KillMode=process
Restart=on-failure
# Hardening
PrivateTmp=yes
ProtectHome=yes
ProtectSystem=full
ReadOnlyDirectories=/
ReadWriteDirectories=-/opt/vpnserver
CapabilityBoundingSet=CAP_NET_ADMIN CAP_NET_BIND_SERVICE CAP_NET_BROADCAST CAP_NET_RAW CAP_SYS_NICE CAP_SYS_ADMIN CAP_SETUID
[Install]
WantedBy=multi-user.target
I have changed the path to /usr/local instead of /opt.
I am planing to add a WorkingDirectory= to se if that helps.
[Unit]
[Service]
Type=forking
KillMode=process
Restart=on-failure
# Hardening
PrivateTmp=yes
ProtectHome=yes
ProtectSystem=full
[Install]
moatazelmasry
Your script looks fine.
How did you obtain SoftEther. Did you compile the source yourself or downloaded the binaries?
Mada
Solved: Problem starting vpnserver with systemd on xubuntu
I was unable to compile the source downloaded from softether.com. And I don think there is binarys to download? ppa:s are old. Instead i used git clone and compiled from there. Thats where I got the sytemd script.
This was the error log:
jan 04 22:17:32 berto vpnserver[1982]: -- Alert: SoftEther VPN Kernel --
jan 04 22:17:32 berto vpnserver[1982]: Fatal Error: The file "hamcore.se2" is missing or broken.
jan 04 22:17:32 berto vpnserver[1982]: Please check hamcore.se2.
jan 04 22:17:32 berto vpnserver[1982]: [1B blob data]
jan 04 22:17:32 berto vpnserver[1982]: (First, reboot the computer. If this problem occurs again, please reinstall VPN software files.)
jan 04 22:17:32 berto systemd[1]: softether-vpnserver.service: Control process exited, code=exited status=255
jan 04 22:17:32 berto systemd[1]: Failed to start SoftEther VPN Server.
This is my script:
[Unit]
ConditionPathExists=!/usr/vpnserver/do_not_run
[Service]
Type=forking
EnvironmentFile=-/usr/vpnserver
ExecStart=/usr/vpnserver/vpnserver start
ExecStop=/usr/vpnserver/vpnserver stop
KillMode=process
Restart=on-failure
WorkingDirectory=/usr/vpnserver
# Hardening
PrivateTmp=yes
ProtectHome=yes
ProtectSystem=full
ReadWriteDirectories=-/usr/vpnserver
[Install]
-- Unit softether-vpnserver.service has begun starting up.
jan 04 22:29:54 berto vpnserver[2097]: The SoftEther VPN Server service has been started.
jan 04 22:29:54 berto systemd[1]: Started SoftEther VPN Server.
-- Subject: Unit softether-vpnserver.service has finished start-up
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- Unit softether-vpnserver.service has finished starting up.
-- The start-up result is done.
This is my script:
[Unit]
[Service]
Type=forking
KillMode=process
Restart=on-failure
# Hardening
PrivateTmp=yes
ProtectHome=yes
ProtectSystem=full
[Install]
moatazelmasry
It might be that the script is not able to find the .so libraries of SoftEther for some reason.
Maybe you can try preloading them in the script using:
LD_PRELOAD="/path/to/each/so /anotherpath"
Mada
Thanks,
adding the WorkingDirectory=/usr/vpnserver seems to do the trick. Now working.
