Help Setup
skullknock
Help Setup
Hello !
i want use softEther vpn as my private vpn (im using openvpn)
Here is my questions
1.Is there any guide "how to set up server in Debian (7, 8, etc)"
2.Is possible to make client accounts like openvpn for each pc im using cuz i dont want same password for my android and for my laptop...
3. Do i need icmp packets Enabled to use the server(net.ipv4.icmp_ignore_all = 1 unable to ping my server)
4.What is the configuration for the firewall(iptables(ports,rules etc) requires before install the server
Thanks!
Thanks!
Re: Help Setup
Please refer this manual.
http://www.softether.org/4-docs/1-manua ... igurations
SoftEther supports multiple account.
If you want to use VPN over ICMP, yes.
Please open ports that you want to use.
skullknock
Re: Help Setup
thanks , there is no debian in manual or ubuntu, i never used cent os or fedora before
and there is no way to install them into my vps
anyways thanks
anyways thanks
Re: Help Setup
There isn't official guide about installation on Debian. However I think you can find unofficial guides by google.
skullknock
Re: Help Setup
There is no Debian Guide to setup :/
fenice
Re: Help Setup
They do have wonderful search engines on the internet these days, use one of those and and search for the words "softethervpn" & "debian" then read the articles you'll find or you could even download the source code and try building it - it's not that difficult and configuration is just the same as every other linux distribution.
skullknock
Re: Help Setup
i tried all google articles with guides and tutorials(all google results up to page 5) >>>>>and the result was to Destroy my vps and re-setup(by the hosting company) was needed
fenice
Re: Help Setup
How is anyone here supposed to know what you've already tried, we're not mind readers. You've also given not details or information about the exact steps you've done nor what the problem was that caused your VPS to be 'destroyed', unless you give details steps on what you've done then nobody will be able to offer you any advice.
skullknock
Re: Help Setup
fenice wrote:
> page
I give up openvpn is enough for me :/
> page
