[Solved somewhat] Windows VPN no network shares
elmo
Hi -
I've seen some similar posts, but haven't found the solution to my issue yet.
I used the wizard to set up a VPN on the work server. I'm using vpnazure and connecting the client using Windows 10 VPN client.
The client authenticates and connects. It gets an IP address on the office LAN. I can ping the IP address and can visit web sites on LAN IP addresses, but I cannot access shares on the LAN!
I can see my home PC on the office LAN, but I also cannot access shares on my home PC.
I have turned off the VPN server's firewall and security software, as well as the client PC software.
Has anyone had this problem and successfully overcome it?
Thanks,
Beth
Thanks,
Beth
elmo
Re: Using vpnazure.net, connecting via Windows VPN no networ
I need to add that I just successfully connected and am browsing the office LAN using a Windows 7 Pro machine, but am still not able to browse the network using Windows 10 Pro or Home. Can anyone suggest a possible solution? Should there be a difference?
Thanks again,
Beth
Thanks again,
Beth
elmo
FWIW, I can access the network shares using the EtherSoft VPN client. I would still like to be able to just use the Windows 10 VPN client, so I will struggle with it until I can get it working.
davidyip
Re: [Solved somewhat] Windows VPN no network shares
I've also problem with Win10 client. I can only connect through vpnazure but not L2TP nor SSTP directlt to the SE server. Anyone have some ideas? Thanks.
Did you configure port forwarding on the router?
davidyip
Yes, 443, 500, 1194, 1701, 4500, 5555.
I even tried from localhost but still failed.
UDP 500 and 4500 are required for L2TP/IPSec.
TCP 443 is required for SSTP.
Other ports aren't needed.
Could you post a server log when connection failed?
davidyip
SSTP:
2017-02-08 17:15:52.831 On the TCP Listener (Port 443), a Client (IP address 42.2.234.198, Host name "42-2-234-198.static.netvigator.com", Port number 56307) has connected.
2017-02-08 17:15:52.831 For the client (IP address: 42.2.234.198, host name: "42-2-234-198.static.netvigator.com", port number: 56307), connection "CID-14-AC9633E96F" has been created.
2017-02-08 17:15:52.902 SSL communication for connection "CID-14-AC9633E96F" has been started. The encryption algorithm name is "AES128-SHA".
2017-02-08 17:15:52.949 Connection "CID-14-AC9633E96F" terminated by the cause "A client which is non-SoftEther VPN software has connected to the port." (code 5).
2017-02-08 17:15:52.949 Connection "CID-14-AC9633E96F" has been terminated.
2017-02-08 17:15:52.949 The connection with the client (IP address 42.2.234.198, Port number 56307) has been disconnected.
Is the log for SSTP connection?
Could you show SSTP client configuration?
davidyip
Please see the attached capture, it is in Chinese but hope you can guess the fields....
Could you try VPN Azure?
davidyip
Yes, VPN Asure is fine.
SSTP Client embedded in Windows OS is checking the server certification is signed by known authority.
Please try to add VPN server certificate to the windows key store.
