Hi...
I have used SoftEther VPN and did not come across this before. Once I connect it states, requesting IP address and never gets one from the router. VPN is connected but it does not work as one since the virtual adapter does not have an IP.
Any insight? I will greatly appreciate it!!!
DEC
No IP Address from the DHCP Server
moatazelmasry
Re: No IP Address from the DHCP Server
Is there a DHCP configured for this virtual adapter?
Kasoze
Thanks for the response. I configured it as I did before...it should obtain from the DHCP server where I installed the SoftEther Server software...it does say its requesting one but does not acquire one.
What OS did you use?
Did you create localbridge?
