Could anybody please tell me how can i assign a Virtual Network adapter to a another phisical network card?
The creation is automatic and always link to the same Network Card.
Thanks in advance
MultiLan VPN client
moatazelmasry
Re: MultiLan VPN client
What do you mean by a virtual network adapter? A tap device created in the local bridge functionality?
neo
When i want to connect to a VPN thru Softether vpn client manager, i have to create a Virtual Network Adapter. This is done automatically, but is attached to my 1st physical network card, and i want to use my 2nd network card.
moatazelmasry
Hmm, if you are on linux, you can change the routing metrics on each network, and give the card you want to use the lowest cost
http://superuser.com/questions/331720/h ... -in-ubuntu
In windows you can change the NIC priority/metric as well
Then hopefully SE will pick the right network automatically
If your "attach" meaning is that VPN communication packets is sent via specific NIC, you should add a route on routing table for the VPN server.
