my name is Adrian and I need your help. I was configuring DHCP option 121 on softether VPN system. Previously, I have configured here the bridge.
Problem is I cannot see nothing in log and I cannot push those classless static routes via this bridge to local router. Can you help me with this issue. It was configured on Ubuntu.
Best regards,
Adrian Bardossy
Problem with split tunneling
moatazelmasry
Re: Problem with split tunneling
Could you please provide more details about your setup.
Where is SE installed, what is the gateway and subnet. SecureNAT or local bridge. Which network are you trying to reach etc..
bardossya
it should work like this.
User will connect to SSTP VPN located on ubuntu server with softether service.
After that client will have IP address 10.0.1.x/24 and using gatewaz on local router on 192.168.1.0/24 subnet.
After whole configuration and selinux located in default location, user cannot obtain routes with DHCPoption 121.
I hope those details will help you to solve my problem.
Thank you.
Adrian
Thank you.
Adrian
bardossya
Sorry for dividing it to 2 mesaages, rputes can be pushed to linux station but to windows stations they cannot be pushed.
Thanks.
Thanks.
bardossya
so the progress is here:
I have configured split tunneling on interface br0
When I have configured here dhcp server, routes can be pushed to linux station, but not to windows station
I have configured some extra routes on softether, the routes are pushed to linux station, not to windows station.
Can you help me how to troubleshoot this?
Thanks.
Thanks.
tschmidty
Are you using secure nat or the local bridge. As in, are you using the SoftEther DHCP server or a DHCP server on your network?
Did you also use SSTP on Linux?
