Hi All,
I'm installed Softether VPN on a raspberry and I have configured succesfully the L2TP protocol. The Raspberry was connected to internet via ethernet.
Yesterday I have changed the connection type from ethernet to Wlan, changing the bridge and using the same IP address that I have before change.
Now I cannot connect to my VPN and I don't see any log for troubleshooting.
Can You help me? Is there a folder where I can see the logs?
Thanks
Marcello
L2TP connection error
Pandora-Box
Re: L2TP connection error
Hello semola,
after changing your connections from ether to WiFi, did you adjust local bridge NIC interface it is using while on WiFI? I mean which LAN adapter your virtual hub is using.
I have also noticed, when I switch SE server from ether to WiFi, I can connect and authenticate, but I am not getting DHCP address, I have to set it up manually on the client to be able to browse remote VPN network.
I hope this might help.
Good Luck
P-B
Good Luck
P-B
semola
I have configured the WiFi adapter using the same values (ip_address, subnet mask, etc) there was using on the ethernet interface (static IP)
About Virtual Hub I have deleted the virtual hub using the ethernet interface and I have created e new one with the WiFi Interface.
The connection reaches the VPN Server (if I see the property of server, I see packets moving when the phone tryes to connect).
Thanks
Marcello
Thanks
Marcello
Please check server_log directory in same directory of executable file.
