Is it possible to install "Softether Server" on the new tinker board from asus?
Rockchip Quad-Core RK3288 processor
2GB Dual Channel DDR3
Debian OS
best regards
ASUS tinker board and Softether?
Fritzbuf
Re: ASUS tinker board and Softether?
> board from asus?
> Debian OS
> best regards
Does anyone had an answer?
> board from asus?
> Debian OS
> best regards
moatazelmasry
It is quite difficult to answer that question, without actually owning similar hardware.
Did you try to install it yourself? what problems did you have?
Fritzbuf
Fritzbuf wrote:
> > board from asus?
> > Debian OS
No, I had no asus tinker board, but i will buy it. Before I will sure that the software "Softether Server" will run on this device. What do you think, can/will the software run on it??
regards
> > board from asus?
> > Debian OS
regards
