How to be a volunteer?
liuxinjianshang
I don't have a volunteer button here
Pandora-Box
Re: How to be a volunteer?
Hi liuxinjianshang,
download vpngate client from http://www.vpngate.net/en/download.aspx or from one of legitimate mirror sites http://www.vpngate.net/en/sites.aspx
and you will be able to participate.
Good Luck.
P-B
Good Luck.
P-B
liuxinjianshang
Pandora-Box wrote:
> Hi liuxinjianshang,
> Good Luck.
> P-B
Thank you for your reply, but...
My SoftEtherVPN Server is download from vpngate.net
My VPS no ”VPNGateSetting“
My home computer yes "VPNGateSetting"
> Hi liuxinjianshang,
> Good Luck.
> P-B
Pandora-Box
Hello liuxinjianshang,
my apologies I thought you wanted to install run VPNGateway client.
Now I see you want to run VPNGate server module on SoftEther server.
Why your two machines behave so very differently it is very puzzling.
I have never seen such behavior.
Maybe you have on your VPS any anti-virus application blocking complete SE server installation.
If so, you might to disable it temporarily.
I would try to re-download fresh the latest version of SE server from http://www.softether-download.com/en.as ... =softether and reinstall it again (first completely uninstall previous installation and remove any remnants).
This is really puzzling.
Sorry, I cannot be of better help.
Good Luck.
P-B
Good Luck.
P-B
Did you install VPN Gate on VPS?
