There is a function or workaround that allow to copy Access List between different virtual hubs or different softether installation ?
Also useful is to duplicate/copy Virtual Hub configuration using one as base for new one.
Access List andother config export/import/copy
oscar.dc
Re: Access List andother config export/import/copy
All configurations about VirtualHub, users, access control list and so on are into config file. If you export it using Manager you can get this information. You can save it automatically using ftp or script that copy the file.
