hi, i hv forget my SoftEther server's password. Read few post here, and also the link below; all of them advice to delete the [HashedPassword] field under the [ServerConfiguration]
https://www.softether.org/4-docs/1-manu ... r_password.
But there is no HashedPassword inside my 'server config' file. it is locate at '/usr/local/vpnserver/vpn_server.config'
I try delete the 'byte Key' after stopping vpnserver, but it will recreate itself and it wont prompt me for new password.
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
uint ConfigRevision 29
string Region MY
declare DDnsClient
bool Disabled false
byte Key F1ZbBXjfDr0mQPmvqy0RH2cOCwA=
string LocalHostname localhost
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
declare IPsec
bool EtherIP_IPsec false
string IPsec_Secret mysecret
string L2TP_DefaultHub DEFAULT
bool L2TP_IPsec true
bool L2TP_Raw false
declare ListenerList
declare Listener0
bool DisableDos false
"vpn_server.config" [dos] 491L, 15929C
Cannot find HashedPassword to reset password
Re: Cannot find HashedPassword to reset password
I think you delete DDNS secret key.
Please delete HashedPassword in 'declare ServerConfiguration'.
