Hi all,
I have successfully installed SoftEther VPN Server and created users in it. The issue I have is that I am unable to establish more than 1 connection to SoftEther VPN from my local network. My Android mobile is connected to wifi and because it is the first device from this public IP, it connects fine. Now, if I try to establish connection from my Macbook which is connected to the same wifi network (i.e., on the same public IP), it fails. The logs says:
2017-05-23 15:20:03.020 IPsec Client 79 (14.231.195.110:32717 -> 50.74.7.145:500): A new IPsec client is created.
2017-05-23 15:20:03.020 IPsec IKE Session (IKE SA) 67 (Client: 79) (14.231.195.110:32717 -> 50.74.7.145:500): A new IKE SA (Main Mode) is created. Initiator Cookie: 0x24F11108DBB25DAD, Responder Cookie: 0xCDB0BBD0FD003296, DH Group: MODP 1536 (Group 5), Hash Algorithm: SHA-1, Cipher Algorithm: AES-CBC, Cipher Key Size: 256 bits, Lifetime: 4294967295 Kbytes or 3600 seconds
2017-05-23 15:20:13.087 IPsec Client 79 (14.231.195.110:32717 -> 50.74.7.145:500): This IPsec Client is deleted.
2017-05-23 15:20:13.087 IPsec IKE Session (IKE SA) 67 (Client: 79) (14.231.195.110:32717 -> 50.74.7.145:500): This IKE SA is deleted.
Also, there seem to be a limit regarding TCP connections (set to value 1) which I seem to hit [screenshot attached] and I do not seem to locate the place where I can modify/increase this value.
NOTE: I can use the same user/pass credentials to connect simultaneously from two or more devices as long as they are on different public IPs. The issue is only when I connect from same network.
Please assist.
Cannot establish multiple connections to SoftEther
vimal7370
Re: Cannot establish multiple connections to SoftEther
If VPN passthrough function available in your network router, please enable it.
or
Please try OpenVPN.
or
Please try OpenVPN.
