I understand that in the clustering solutions each session is assigned a vpn server in a load balancing fashion.
1. What are the load balancing algorithms? 2-tuple? 4-tuple?
2. It is unclear whether all packets still go through the master server even after a dedicated vpn server has been assigned. Could you clarify that?
Thanks,
Howling
Packet flow in clustering solution
Re: Packet flow in clustering solution
The load balancing algorithm is this.
http://www.softether.org/4-docs/1-manua ... dard_Ratio
Packets doesn't go through the controller server.
