I am having an issue with transferring files from my softether server to a softether client.
I am using softether protocol over port 5555.
The client connects to the vpn server just fine. I can browse file shares on the server from the client no problem. I can browse file shares on the client from the server no problem. I can send a very small text file from the server to the client (using windows SMB/shares) without issue. If I try to send a larger file (several MB) the transfer just hangs for a few minutes, maybe progressing a couple of percent, and then I get an error message stating that the transfer failed.
Transferring files from the client to the server over SMB/shares works perfectly and FAST.
I initially thought my symptoms lined up very well with this post
http://forum.softether.org/viewtopic.ph ... 10&start=0
but then I tested setting up an FTP server on the VPN client side, and FTPing a file from the VPN server to the VPN client, and that actually worked, althought it was VERY slow. 20 minutes to transfer a 6mb file.
[code]
Here is my server config
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
uint ConfigRevision 43
string Region $
declare DDnsClient
bool Disabled true
declare IPsec
bool EtherIP_IPsec false
string IPsec_Secret REDACTED
string L2TP_DefaultHub HOME
bool L2TP_IPsec false
bool L2TP_Raw false
declare ListenerList
declare Listener0
bool DisableDos false
bool Enabled false
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
declare LocalBridgeList
bool EnableSoftEtherKernelModeDriver true
bool ShowAllInterfaces false
declare LocalBridge0
string DeviceName REDACTED
string HubName HOME
bool LimitBroadcast false
bool MonitorMode false
bool NoPromiscuousMode false
declare ServerConfiguration
bool AcceptOnlyTls true
uint64 AutoDeleteCheckDiskFreeSpaceMin 8589934592
uint AutoSaveConfigSpan 300
string CipherName RC4-MD5
uint CurrentBuild 9634
bool DisableDosProction false
bool DisableOpenVPNServer false
bool DisableSSTPServer true
bool DontBackupConfig false
bool EnableVpnOverDns false
bool EnableVpnOverIcmp false
byte HashedPassword REDACTED
uint KeepConnectInterval 50
uint KeepConnectPort 80
uint KeepConnectProtocol 1
uint MaxConcurrentDnsClientThreads 512
uint MaxConnectionsPerIP 256
bool NoDebugDump false
bool NoSendSignature false
string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tls-client
bool SaveDebugLog false
byte ServerCert REDACTED
byte ServerKey REDACTED
uint ServerLogSwitchType 4
uint ServerType 0
bool Tls_Disable1_0 false
bool Tls_Disable1_1 false
bool Tls_Disable1_2 false
bool UseKeepConnect true
bool UseWebTimePage false
bool UseWebUI false
declare GlobalParams
uint FIFO_BUDGET 10240000
uint MAX_BUFFERING_PACKET_SIZE 2560000
uint MAX_HUB_LINKS 1024
uint MAX_IP_TABLES 65536
uint MAX_MAC_TABLES 65536
uint MAX_SEND_SOCKET_QUEUE_SIZE 2560000
uint MAX_STORED_QUEUE_NUM 1024
uint MEM_FIFO_REALLOC_MEM_SIZE 655360
uint MIN_SEND_SOCKET_QUEUE_SIZE 320000
uint QUEUE_BUDGET 2048
uint SELECT_TIME 256
uint SELECT_TIME_FOR_NAT 30
uint STORM_CHECK_SPAN 500
declare ServerTraffic
declare RecvTraffic
uint64 BroadcastBytes 238024929
uint64 BroadcastCount 1616505
uint64 UnicastBytes 83437421001
uint64 UnicastCount 279188662
declare SendTraffic
uint64 BroadcastBytes 130140859
uint64 BroadcastCount 952556
uint64 UnicastBytes 186131526
uint64 UnicastCount 1523344
declare SyslogSettings
string HostName $
uint Port 514
uint SaveType 0
declare VirtualHUB
declare HOME
uint64 CreatedTime 1498058826521
uint64 LastCommTime 1498627430507
uint64 LastLoginTime 1498626698273
uint NumLogin 14
bool Online true
string RadiusRealm $
uint RadiusRetryInterval 0
uint RadiusServerPort 1812
string RadiusSuffixFilter $
byte SecurePassword REDACTED
uint Type 0
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_empty_password 0
uint deny_qos 0
uint deny_routing 0
uint max_accesslists 0
uint max_bitrates_download 0
uint max_bitrates_upload 0
uint max_groups 0
uint max_sessions 0
uint max_sessions_bridge 0
uint max_sessions_client 0
uint max_users 0
uint no_cascade 0
uint no_change_access_list 0
uint no_change_cert_list 0
uint no_change_crl_list 0
uint no_change_groups 0
uint no_change_log_config 0
uint no_change_msg 0
uint no_change_users 0
uint no_delete_iptable 0
uint no_delete_mactable 0
uint no_disconnect_session 0
uint no_enum_session 0
uint no_offline 0
uint no_online 0
uint no_query_session 0
uint no_read_log_file 0
uint no_securenat 0
uint no_securenat_enablenat 0
declare CascadeList
declare LogSetting
uint PacketLogSwitchType 4
uint PACKET_LOG_ARP 0
uint PACKET_LOG_DHCP 1
uint PACKET_LOG_ETHERNET 0
uint PACKET_LOG_ICMP 0
uint PACKET_LOG_IP 0
uint PACKET_LOG_TCP 0
uint PACKET_LOG_TCP_CONN 1
uint PACKET_LOG_UDP 0
bool SavePacketLog true
bool SaveSecurityLog true
uint SecurityLogSwitchType 4
declare Message
declare Option
uint AdjustTcpMssValue 0
bool DisableHttpParsing false
bool DisableIPParsing false
bool DisableIpRawModeSecureNAT false
bool FilterBPDU false
bool FilterIPv4 false
bool FilterIPv6 false
bool FilterNonIP false
bool FilterOSPF false
bool FilterPPPoE false
bool ManageOnlyPrivateIP true
uint MaxSession 0
bool NoArpPolling false
bool NoEnum false
bool NoIpTable false
bool NoIPv4PacketLog false
bool NoIPv6AddrPolling false
bool NoIPv6PacketLog false
bool NoLookBPDUBridgeId false
bool NoMacAddressLog true
bool NoManageVlanId false
uint RequiredClientId 0
string VlanTypeId 0x8100
declare SecureNAT
bool Disabled true
bool SaveLog true
declare VirtualDhcpServer
string DhcpDomainName hamfam.com
bool DhcpEnabled true
uint DhcpExpireTimeSpan 7200
string DhcpLeaseIPEnd 192.168.30.200
string DhcpLeaseIPStart 192.168.30.10
string DhcpPushRoutes $
declare VirtualHost
string VirtualHostMacAddress 00-AC-AC-14-AB-C8
declare VirtualRouter
bool NatEnabled true
uint NatMtu 1500
uint NatTcpTimeout 1800
uint NatUdpTimeout 60
declare CertList
declare CrlList
declare GroupList
declare IPAccessControlList
declare Acl1
bool Deny false
string IpAddress REDACTED
uint Priority 100
declare Acl2
bool Deny true
string IpAddress 0.0.0.0
string NetMask 0.0.0.0
uint Priority 200
declare UserList
declare ham-backup
uint AuthType 2
byte AuthUserCert REDACTED
uint64 CreatedTime 1498059566345
uint64 ExpireTime 0
string Note $
uint NumLogin 14
string RealName $
uint64 UpdatedTime 1498106613167
declare Traffic
declare RecvTraffic
uint64 BroadcastBytes 88823204
uint64 BroadcastCount 596903
uint64 UnicastBytes 61839161
uint64 UnicastCount 189594
declare SendTraffic
uint64 BroadcastBytes 41420526
uint64 BroadcastCount 356824
uint64 UnicastBytes 74090291
uint64 UnicastCount 340238
declare Traffic
declare RecvTraffic
declare SendTraffic
[/code]
I could use FTP, but I would much prefer to use SMB. Any help you can provide would be greatly appreciated!
Taylor
issue transferring files from server to client
snarfsmojo
Re: issue transferring files from server to client
Could you try to decrease the MTU value of virtual NIC?
