hi hope you are well.
i need to ensure 3 things using softeether -
1) tls 1.2 is used
2) that 2fa can be used.
3) rate limiting the number of password attempts / blacklisting Ip's that try too much
does anyone know if this is possible please?
tls1.2 and 2fa
Re: tls1.2 and 2fa
>1) tls 1.2 is used
SoftEther VPN supports TLS 1.2 from SoftEther VPN 4.22.
http://www.softether.org/5-download/history
SoftEther VPN doesn't support 2fa by itself.
However, some users try 2fa with Radius.
http://www.vpnusers.com/viewtopic.php?f=7&t=8709
SoftEther VPN has DoS attack protection function.
