VPN Client MAC address assignment
deb_user
I'm running the latest version of SoftEther VPN Server on Debian 8. I'm using my own DHCP Server (SecureNAT is completely disabled). Everything works fine. But i did not found a way to give a client a fixed IP address, because the VPN server does not give the same MAC address to the client, when the connectuon order of all clients changes. Why is this? Is it even possible to assign a fixed IP to a client with my external DHCP server?
Best Regards
Best Regards
deb_user
Re: VPN Client MAC address assignment
No one can help?
deb_user
Is there no way to achieve this?
Please check property of virtual NIC.
deb_user
Where do i have to check that? On my router (DHCP Server)? My router is a pfSense box.
Best Regards
Best Regards
Please check VPN client (not router).
deb_user
On the client side i'm using the Windows 10 built-in vpn client.
deb_user
What do you mean exactly?
L2TP client doesn't report own MAC address to the server.
So the MAC address is generated from session name.
deb_user
Before i had a openswan Server, where it was possible to set fixed IP's to the usernames, so are you sure, there is no way to achieve this in SoftEther?
SoftEther VPN server can accept multiple session by one user.
Then, in your way, MAC address will conflict.
If you can handle the problem, please improve the SoftEther VPN code.
