please smb tell me why there is no option in "Local bridge setting" to "Bridge to a new tap device" in SoftEther GUI?
No option in Local bridge to "Bridge to a new tap device
BalRoG
BalRoG
Re: No option in Local bridge to "Bridge to a new tap device
too difficult question?
raafat
Usually you choose from the items that are listed with LAN adapters to create your bridge. What are you trying to do ?
Tap is supported on Linux version only.
Does the VPN server run on Linux?
BalRoG
I run it on Windows, thank you very much for the answer! Now i get it
