Hi there,
I have a OpenVPN Clone Server running and want my clients to use the local gateway (VPN Gateway).. Windows Clients don't have a problem, I can define the gateway on the VPN network adapter.. But what about the Android Clients?
Please see the attached picture for further explanation..
Thanks and best regards
Stefan
Howto set Gateway for OpenVPN Clients
glockmane
Re: Howto set Gateway for OpenVPN Clients
Could you check the VPN server log?
