VPN Client can not get IP from VPN Server
Dear Admin,
I setup an VPN softether server on windows 10 machine and everything seem to be ok. However when i tried connect from other computer VPN softether Client software, I can not get an IP address and it keep showing my IP: 169.254.84.69 (mean can not get the IP from the DHCP VPN server).
Please help. I tried to fix it but It can not work. And now I'm desperately looking for help!
I looking forward to hearing from you soon.
Thanks.
Thanks.
Re: VPN Client can not get IP from VPN Server
I wonder if the different Built has different functioning? Is there any problem with the Beta and the other one?
Should I remove the beta one with the stable one to fix the problem of the VPN Server didn't release an IP address?
Is there anyone has the same problem? Help, please.
I have the same problem, but not with all client and place.
I own a test environement with 3 ADSL.
The client connected directly to ADSL-3 (no fireall) alway get and IP address, the other 2 that have firewall, casually do not get DHCP, also i i see in firewall log the message ... Offered IP x.x.x.x from a DHCP server.
I think is a firewall problem
Bye
Alex
Bye
Alex
>nhatminh1209
Did you create a localbridge?
> Bye
> Alex
And I dont think it is because of firewall. Firewall has nothing to do here. We are using VPN which means we connect through port 443 or something else the Softether vpn server default set up. In case, the firewall doesn't block the port, we still could connect to it.
The problem here may be because of the configuration of the VPN Server that we don't know.
I have problem connecting from MAC and LINUX too. Anyone has problem connecting from Linux and MAC?
> Bye
> Alex
thisjun wrote:
> >nhatminh1209
I connetct as usual.
> >nhatminh1209
Did you read the tutorial?
http://www.softether.org/4-docs/2-howto ... VPN_to_LAN
I did. and it doesn't happen to me all the time. Sometime and depend on the machine (Windows). and I also has problem connecting to the server from both Lĩnux and Mac. Could you please help me how to solve problem when I connect from Linux or Mac?
What did you?
And, is there a DHCP server on the LAN?
I have the same experience, not always the IP adress is gotten at the first connect, normally disconnect and connect again makes me getting the ip-adress from the lan on which the vpn-server risides.
I am thinking to make a command-script to solve this, since some of my VPN users experience the same problem.
