Local Bridge on MS Hyper-V
Mahdi
Post by Mahdi » Sat Apr 06, 2013 12:12 am
Hi all
At the moment the VPN server is running on a VPS in a Hyper-V cloud. It seems that I can create a local bridge such that after creation it statues becomes "operating" however there is not any bridge connection in "network connections" and the command "netsh bridge show adapter" returns nothing, In fact the only available connection is the original "local area connection". Therefore the clients cannot pass their traffic via the bridge while there is a session for the bridge in virtual hub. (DHCP is running on the virtual HUB )
Re: Local Bridge on MS Hyper-V
Post by cedar » Sat Apr 06, 2013 3:23 pm
Local bridge function of VPN Server is different thing from Windows bridging function.
Please try to set MAC spoofing enable on your Hyper-V server.
http://blogs.technet.com/b/jhoward/arch ... ofing.aspx
YeMojuD
Post by YeMojuD » Sun Apr 14, 2013 4:52 pm
I have same problem with Windows 2008 VPS (VMware ESX).
How can solve it?
Post by cedar » Tue Apr 16, 2013 2:28 am
This setting is called as 'promiscuous mode' in VMware.
http://2.bp.blogspot.com/-qMnMUUtg7No/U ... scuous.png
YeMojuD
Post by YeMojuD » Wed Apr 24, 2013 5:35 am
Thanks cedar
Now I get ip address after connect to VPS, but can't access internet.
Post by cedar » Wed Apr 24, 2013 6:48 am
If your client connect to the network of data-center, your client may be not assigned a proper IP address from data-center.
Please use virtual NAT instead of local-bridge in VPS.
YeMojuD
Post by YeMojuD » Wed Apr 24, 2013 8:49 pm
Thanks, I test secure Virtual Nat and it's very slow!
