in my server i save ovpnconfgifile and copy on the folder config ovpn GUI but when Press connect Hold on Auth error i define username and passsword in Virtual Hub ?
How Can fix it?
see This Error
Sun May 05 11:59:11 2013 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
						Use openvpn On softehetr server
				barrierfr
Re: Use openvpn On softether server
If I understand well your quesiton, you have defined your virtual hub, you have define at least one ID and password in the vpn server.
For the openvpn client, don't use the last one openvpn provide. I had the same issue I'm using a 2.1 version. I thnk the very last one don' suit the current softether version.
If this doen's fix your issue, have a look on your server and check the vpnserver/server_log/vpn_xxxxx.log you will see really what's wrong in your access.
Let us know here what was your issue and what I told you fixed it.
Rgds
Fred.
Rgds
Fred.
