Can not surf after CSF enabled
Gulaholic
Post by Gulaholic » Wed May 29, 2013 2:21 pm
I have a problem with my VPN Server.
After I enabled CSF Firewall the connectivity to other IP is blocked.
I have tried to uninstall CSF firewall but it still won't let me surf the web.
Please help me.
Re: Can not surf after CSF enabled
Post by cedar » Wed May 29, 2013 11:00 pm
It seems that CSF changes the OS network setting.
Please try to re-install CSF and re-configure to original setting.
Gulaholic
Post by Gulaholic » Thu May 30, 2013 1:57 am
Hi cedar,
I did that but same thing happened. Finally I reinstalled the OS and softether.
Do you think it is possible to integrate CSF to SoftEther safely?
I'm thinking that CSF override basic IPTABLES setting from SoftEther when activated.
Mainly I want to block ports used for torrent.
Gula
Post by cedar » Thu May 30, 2013 8:52 am
I am sorry.
Because I am not familiar with the CSF, I don't know the specific behavior.
Gulaholic
Post by Gulaholic » Thu May 30, 2013 11:17 am
Hi cedar,
Do you have any suggestion of what should I do to block all torrent ports?
Thanks
Post by cedar » Fri May 31, 2013 3:19 pm
You can block traffic in a virtual hub with Access List function.
http://www.softether.org/4-docs/1-manua ... ccess_List
