All ip of vpngate was blocked by chinese govment!
Re: All ip of vpngate was blocked by chinese govment!
Browse mirror sites and use UDP instead of TCP by filling in wrong TCP port.
I can download the software,but no one ip can connect by tcp,I will test udp port again
Don't forget to visit vpngate by mirror sites
http://pl2079.nas829.p-tokyo.nttpc.ne.j ... /mail.aspx
I can always find few IP can be used, but two days ago, I found that all IP was blocked by the government, it's hard to find a ip can use, if there are some Chinese people can use normally vpngatge,please tell me!
Some people in this forum said that if a softether vpn connection is detected, the IP will be blocked immediately by GFW. And if they use vpnazure, they can connect but can only browse foreign websites and Chinese websites are inaccessible. I will try if the VPN servers can access Chinese websites.
Yes, Chinese websites are really inaccessible via some Vpngate VPNs
vpnazure?other project by softether?
You can say so and the URL is correct.
You can try to replace xxx.opengw.net with xxx.vpnazure.net and connect to the server by SSTP and enter username:vpn and password:vpn. However, it may not work because this function is not enabled by default on the server.
*You need to compare the IP of xxx.softether.net(replace xxx.opengw.net with xxx.softether.net) and xxx.vpnazure.net first by nslookup function. If the IP is the same, then it shows the server did not enable VPNAzure.
thnaks!what's different between vpngate and vpnazure?vpngate use ip to connect vpn peer,Do vpnazure use ddns name,is it better than vpngate?
VPNAzure is the function of the server side. If the function is enabled, clients will be able to connect to xxx.vpnazure.net using SSTP and there is no need to open any port in the firewall. This function is available in both Free version Softether VPN and Commercial version PacketiX VPN.
Reference: http://www.softether.cn/chanpin/PacketiXVPNV4.html
*There is also a review that if free version of softether vpn server is set outside China and connect to it with a China IP. The server address will be blocked as I stated previously but there is no problem on commercial version PacketiX.<--Legally sold in China
