@ In usernames
gavstah
@ In usernames
Post by gavstah » Tue Oct 29, 2013 12:08 pm
Hi there -
Is there any way to allow @ in a username in softether? Right now it does not seem to allow it.
kh_tsang
Re: @ In usernames
Post by kh_tsang » Tue Oct 29, 2013 12:18 pm
Usernames for non-Softether VPN Client connections are defined as [username]@[virtual hub name].
inten
Re: @ In usernames
Post by inten » Tue Oct 29, 2013 12:37 pm
There is no way to use @ (email address like). Sad but true.
When you connect with non-softether client (i.e. Windows client), the client presents a username to the VPN Server and if you didn't specify @HUB_NAME, then the set by default hub will be used.
You have to be careful because your VPN client may connect to the wrong IP subnet.
inten
Re: @ In usernames
Post by inten » Tue Oct 29, 2013 12:44 pm
I believe this is a question of SoftEther design. Nevertheless it would be great to receive answers from disappeared developers to so many questions are being left without the answer.
