problem with idle connection
soheilsh
hi .my name is soheil from iran . thanks for your softether vpn.
when connected to a Softether VPN Server with the VPN Client,
Some packets are sending and receiving .i monitor adapter in idle time .softether vpn in all time uses send and receive . in 6 hours 300 MB send and receive uses
and this when using openvpn or ipsec client windows to connect softether server no problem just problem with server client softether
how to fix problem?
how to fix problem?
Re: problem with idle connection
SoftEther VPN client act like as an Ethernet adapter.
Many Windows services try to send broadcast query and announcement to the Ethernet LAN automatically.
I suggest to stop Windows file sharing protocol on the virtual network adapter.
If you use broadcast based network service like as Bonjour or UPnP, it good idea to stop it.
mamal_123
> adapter.
> idea to stop it.
Could you clarify how to stop Windows File Sharing protocol on the virtual network ?
> adapter.
> idea to stop it.
soheilsh
> adapter.
> idea to stop it.
thanks for replay ,
i disable all services my softether adapter and not happening.
10-30 Kbps all time uses send and receive data
i uses windows 8 operation system and softether Vpn build-9038
> adapter.
> idea to stop it.
thanks for replay ,
Please see like this page.
http://www.hardwaresecrets.com/article/ ... ions/137/2
Please install Wireshark to snoop traffic on the network.
Wireshark can analyse network traffic on specified adapter.
soheilsh
> network ?
i install wireshark and all time 15kbps send and resive packet data
> network ?
soheilsh
> network ?
i monitor ethernet card softether.
please see the picture
send data to england Ministry of Defence ?
please explain for this that
> network ?
dnobori
I suppose there are some malware or botnet agents in your computer.
You should check your PC with anti-virus software.
soheilsh
i try to another system and problem has been not sloved
soheilsh
please help
soheilsh
Guest wrote:
> i fix this problem by delete the bridge connection in bride settings :)
> Thanks for your amazing program :)
I also had bridge connection, I deleted it but nothing changed
Did you try a packet capture?
When you see where to send the packet, please try to look at the processes that are sent in "netstat-ab" command.
