SoftEther Site to Site with Cisco ASA 5520
SAMbI4
Re: SoftEther Site to Site with Cisco ASA 5520
Post by SAMbI4 » Wed Jul 29, 2015 12:02 pm
same question....somebody make it?
SAMbI4
Post by SAMbI4 » Fri Jul 31, 2015 7:59 am
SAMbI4
Post by SAMbI4 » Mon Aug 03, 2015 8:12 pm
up again....
sgunnestad
Post by sgunnestad » Tue Oct 16, 2018 5:53 pm
Noone has ever gotten this to work? The article at https://www.softether.org/4-docs/2-howt ... uter_Setup seems lacking, even though the Cisco solution is boasted as the best solution.
AFAIK, the L2TP tunnel should be terminated to a virtual HUB as per the diagram, even if connecting with a L2TP device?
I don't see that there is an IP to assign to the L2TP device/tunnel in the Virtual Layer 3 Switch for the remote site.
Also, I don't see what ethernet device the Local Bridge should connect to for the remote site (Osaka in the diagram)
Any hints would be appreciated.
I have read all of the documentation on this without finding any good solution.
Fork1337
Post by Fork1337 » Wed Oct 17, 2018 7:21 am
I'm having the exact same issue as sgunnestad.
Any solution here?
Post by thisjun » Thu Nov 01, 2018 6:40 am
Localbridge can't bridge to a remote site.
Localbridge is for local bridging as its name suggests.
sgunnestad
Post by sgunnestad » Fri Nov 02, 2018 2:44 pm
So how is the Cisco unit supposed to authenticate to the L3 Switch?
Is this supposed to work at all? Reading from
https://www.softether.org/4-docs/2-howt ... olution%3F
Why does it not exist any good manual for this? It seems other people who have tried to get this working have given up?
If I get it working I will publish a proper guide.
Regards
Post by thisjun » Thu Nov 15, 2018 8:06 am
Which L3 switch are you asking about?
sgunnestad
Post by sgunnestad » Sat Nov 17, 2018 1:46 pm
The Cisco endpoints are authenticating to something at the central site. Doing this with bridge mode works well but I fail to understand how to configure this with routing.
Post by thisjun » Tue Dec 11, 2018 2:07 am
The Virtual L3 switch is just a generic router.
There isn't authentication.
Please just specify IP address of the virtual interface as a gateway.
sgunnestad
Post by sgunnestad » Wed Jan 02, 2019 1:28 pm
Could you point me to the relevant documentation for this?
Post by thisjun » Mon Feb 04, 2019 6:25 am
This is manual of virtual L3 switch.
https://www.softether.org/4-docs/1-manu ... 3_Switches
