中国からのSoftether VPN接続
vpngate2015
Re: 中国からのSoftether VPN接続
Post by vpngate2015 » Tue Oct 14, 2014 8:29 am
I surfer internet at school, under windows 7, i should open the Ruijie client to connect the internet, when i open vpngate , and choose "VPN Gate Service Control Panel" will appear. Check the "Enable the VPN Gate Relay Service and Join the VPN Gate Research as a Volunteer" checkbox. After that, click the "VPN Gate Service Option Settings" button. then my computer will appear that you can't connect the network card, i can't find my network card in the option of Ruijie software . it's missing! so, HELP!
The Ruijie (锐捷)client reference: http://www.gdufs.edu.cn/fwdh/wlfw/xywsy ... jjsysc.htm
Post by cedar » Tue Oct 14, 2014 12:28 pm
You don't need to enable the VPN Gate Relay Service.
This function is for providing the VPN relay service to the others all over the world.
You should find a VPN Gate server and connect to it.
vpngate2015
Post by vpngate2015 » Wed Oct 15, 2014 2:21 am
but if i want to be a volunteer, how to fix this problem?
Post by cedar » Wed Oct 15, 2014 8:53 am
If you want to host VPN server, why don't you setup normal VPN Server instead of VPN Gate?
vpngate2015
Post by vpngate2015 » Wed Oct 15, 2014 9:05 am
OK, if i have time, i will have a try, thanks!
