Guest wrote:
> Edit:
> in idle run: 2kb/s transfering and this trrafic is non stop
> when vpn disconnected, the transfer rate = 0 kb/s
yes i have this problem too !
http://www.vpnusers.com/viewtopic.php?f ... p=652#p652
Why the softether trrafic more than vpn or proxy?
soheilsh
sorset
Re: Why the softether trrafic more than vpn or proxy?
Try to disable "Use keep alive internet conenction" at server side.
You can find at Encryption and Network settings.
