softether for amd cpu
omar
Post by omar » Thu Aug 02, 2018 2:22 pm
i have ( amd a8 ) processor and i can't use softether vpn. is there any fix ?
Re: softether for amd cpu
Post by cedar » Tue Aug 07, 2018 5:41 am
What error did you see?
omar
Post by omar » Tue Aug 14, 2018 7:47 am
my processor is AMD A8 and this the message i get when i use the program
Post by cedar » Tue Aug 21, 2018 2:53 am
This error also occurs when the VPN server is not running or there is no route to the server.
Is something like a security software or a firewall inhibiting communication?
omar
Post by omar » Tue Aug 21, 2018 4:58 pm
i installed the program at work with the Intel processor and it worked fine. it's just that it does not work with AMD Processor.
Post by cedar » Wed Aug 22, 2018 10:09 am
SoftEther VPN is operating normally on many AMD hosts.
It's natural to think that there are other factors in the problem.
