Mikrotik + softether
maks83
Post by maks83 » Sat Oct 06, 2018 6:59 pm
Hello. Please help me.
I have:
Softether VPN Server (with configured LAN, 192.168.1.0/24).
Mikrotik with configured LAN 192.168.10.0/24) and L2TP Client connected to Softether VPN Server.
Mikrotik works fine (I can get access from 192.168.10.0/24 to 192.168.1.0/24).
How could I configer Softether VPN Server to get access from 192.168.1.0/24 to 192.168.10.0/24?
maks83
Re: Mikrotik + softether
Post by maks83 » Sun Oct 07, 2018 4:54 am
sky59
Post by sky59 » Sun Oct 07, 2018 5:28 am
Everything is static addresses? What is dlink doing? Can it be router and switch at the same time?
Why you make "chaos" and in text you write everywhere address of the network xx.xx.xx.0 ?
Can you be more exact?
maks83
Post by maks83 » Sun Oct 07, 2018 5:43 am
Dlink have global IP, mikrotik have not global IP (USB 3g modem)
Yes.
Sorry
sky59
Post by sky59 » Mon Oct 08, 2018 10:30 am
sorry, but you really make a mess! on the picture that pings there are adresses nobody can guess what is what...
try to your PC on right side write physical address 192.168.1.192 (? server address) it must work
if not, thed Dlink blocks seeing neigbours on the right side..... my idea
