Unable to install VPN client
XeXLNX
Post by XeXLNX » Sun Oct 07, 2018 3:27 pm
When one of my clients tried to install the VPN client to connect to my OVH he is getting this error.
The setup program has been executed from outside an install source.
Unable to continue the installation.
What could be causing this issue?
Re: Unable to install VPN client
Post by thisjun » Thu Oct 18, 2018 7:05 am
This message means that the installer failed to extract temporary files.
Please check temp environment variable is configured properly and a security software deletes something.
