I had been trying to setup the SoftEther VPN server on MS Azure Cloud, and I wish to be able to connect multiple Mikrotik routers of different networks, and all be able to route with each other. The VPN server resides on Azure cloud on a Linux VM. Here is the configuration of the VPN server:
Two Virtual Hubs (VHub):
1. Default
  Local Bridge to eth0 of the Azure VM. VM eth0 has IP address: 10.0.1.4
2. Office
  L2TP tunnel established with this VHub. SecureNAT/Virtual DHCP is on to provide IP address for this tunnel.
  Virtual Host network Interface
    IP Address: 192.168.31.1
  Virtual DHCP Server
    IP Address Lease Range: 192.168.31.21-200/24
Layer 3 Switch is set:
  Farm1 -
    Virtual Interface: 10.0.1.254/24 | VHub: Default
    Virtual Interface: 192.168.31.2/24 VHub: Office
    Routing Table: 10.185.93.0/24 GW: 192.168.31.10 Metric:1
I also have a testing VM setup in the same Azure subnet with IP address 10.0.1.5. When I ping from 10.0.1.5 to 10.0.1.4, I am able to ping since it's the Azure VM that was answering. However, when I pinged from 10.0.1.5 to 10.0.1.254, which is the virtual interface address of VHub Default, I am getting timed out. Is there something that I am missing here? Thanks a lot in advance for your help.
Cheers
						Local Bridge on MS Azure Cloud
				scsimon
Re: Local Bridge on MS Azure Cloud
Any one has similar issue to what I am having now? Not sure if it's a limitation on Microsoft Azure or a SoftEther limitation, or if it's just a setting issue. Thanks.
I have never try to create a localbridge on MS Azure, however, cloud service usually doesn't allow spoofing of MAC address.
So, I think the localbridge doesn't work.
