Hi to all, i'm a newbie on VPN, and i've some personnel question.
I have a network that I would like to access remotely.
This network is connected to two wans.
The first one with a public IP address, the second one, i would like to use as failover, the router support this function,
it's 4G WAN, that doesn't have public address because the provider use a NAT.
The network router has the built in function for IPSEC/L2TP client and server, I have the availability of a cloud server too i could use for
SofthEther server or bridge, my question is, can i have a vpn through the 4G wan even if this has an hide ip address from the provider nat ?
Which kind of SofthEther configuration should i use ?
Thank you.
PC to Lan connection on Multiple LAN Failover
Geremiah
Re: PC to Lan connection on Multiple LAN Failover
If the 4G WAN doesn't have a public IP address, SoftEther VPN Client can't reach the 4G WAN.
